December 04, 2008, 02:44:14 PM
It truely is sad to see a car club that I knew in the PNW back in '98 /'99 go to shit with people like you and all your east coast cloanies. Now i see why some of the "original" crew have left the scene. Looks like a bunch of DEMONIC WHOREDs who run nothing but there fucking mouth in the DCI now........... - Euro2.0
76095 Posts in 5909 Topics by 441 Members
Latest Member: Btfxssnk
| | |-+  Electronics & Accessories
| | | |-+  16V fans
Author Topic: 16V fans  (Read 1192 times)
Oldskool84
16V fans
« on: October 15, 2006, 10:25:09 AM »
From what I'm seeing, there are no relays in this system.  Is this correct?  I'm running the 2 speed fans with the 3 pin thermoswitch.  When the car was running last, I hooked it up just using the high-speed setting and the lower of the 2 pins on the switch (#2--95C).  I threw a relay in between the load of the switch and the fan as I wasn't sure of the set-up.
I want to hook it up now factory style using both speeds.  I'm not seeing a relay though like on the single speed cars.  The only thing I see is the after-run relay.
Is it wise to leave it with no relay(s), or should I add 2 in the mix?  Thanks.
"Just add more timing, you'll be fine."------ VR6 Paul
'96 GTI VR6 ...  24.00 @ 2500
                       (quarts @ miles)
Re: 16V fans
« Reply #1 on: October 16, 2006, 10:06:55 AM »
man, it would be rad if someone has a how to make your own rad fan wireing set up for 2 speeds using simple on off relays and what not.....  as ihave to do this for 2 of my stinking cars. i dont want that big box vr6's use as its a pos......a nd my rabbit will ned some mad tech rad fan set up also. didnt someon around here say they had a simple way to do all this for under a bizillon buks?
Oldskool84
Re: 16V fans
« Reply #2 on: October 16, 2006, 12:39:47 PM »
That's what I'm talking about.  I looked at the VR bentley and didn't see anything about a fan relay or control box.  Am I missing something?
                       (quarts @ miles)
Re: 16V fans
« Reply #3 on: October 16, 2006, 03:17:21 PM »
It would be really easy to rig that up via relays.  But also if the factory isn't using relays in earlier cars you could probably safely run them full power thru the fan control switch.  I've been thinking of doing this as well, as I need to redo the wiring on the Cabby's fan.
Too busy now tho, school's finally catching up with me in week 4.
Oldskool84
Re: 16V fans
« Reply #4 on: October 16, 2006, 04:32:29 PM »
That's what I'm saying.  I looked at a VR and a Passat 16V Bentley and I don't see a fan control unit.  Maybe I'm missing it.  The Rabbits def. have one.
I'm just going to run a change-over relay for both speeds and be done with it.
                       (quarts @ miles)
Oldskool84
Re: 16V fans
« Reply #5 on: October 16, 2006, 05:02:33 PM »
Eh that won't work.  I'll have to do two relays.  Word.
                       (quarts @ miles)
16VCorey
Re: 16V fans
« Reply #6 on: October 17, 2006, 05:02:45 AM »
I wired the last one I did directly.  It worked perfectly for the three years my brother had the car.  I just ran a hot wire to the power side of the switch, a wire from the low temp switch spade to the low speed spade on the fan, a wire from the high temp switch spade to the high speed fan spade, and a ground to the ground spade on the fan.  As long as you have a three prong switch and a three prong fan, four wires and your done.
Re: 16V fans
« Reply #7 on: October 17, 2006, 09:35:19 AM »
i think vw knew there fan contorl realy box is crap and they tryed topretnd it never existed when they instelled them. i hate them fucking pos things.......
ok so who's going to make up the diagram to do this w/ and w/ out relays?....... i lke to poop........ an di like candy....
Oldskool84
Re: 16V fans
« Reply #8 on: October 17, 2006, 05:28:06 PM »
W/O relays is simple.
Hot wire, fused 30A to terminal #3 on the switch.
Terminal #1 goes to #3 on the fan.
Terminal #2 goes to #2 on the fan.
#1 on the fan goes to ground.
Adding relays would be like this.  The + 12 you could grab from the power supplying the fan power.
#1 on the stock switch is the 105 deg.C.    #2 is the 95 deg. C.
#2 on the fan is low speed.  #3 is high speed.
Somebody double-check me.
                       (quarts @ miles)
Re: 16V fans
« Reply #9 on: October 17, 2006, 05:59:15 PM »
That looks good to me Julian.
16VCorey
Re: 16V fans
« Reply #10 on: October 18, 2006, 05:16:29 AM »
What he said.
