got the fuel system put together last night, even pressure tested it.
first try, no leaks.. I was surprised.
this is the compression fitting, 1/4NPT to 1/4NPT female to female into the -6an barb (on the right side of the pic is the innovate wideband controller):
this is the fuel filter, which sits right above the bellhousing below the side coolant flange on the head:
both lines come up from that level into the new FPR adapter:
shot of what it looks like from the front, with a lot of the other shit put on as well:
also rerouting the oil pressure stuff around the drivers side of the head with 42's oil pressure relocation kit coming out of an adapter on the oil filter flange (the second port on the top of it will be plugged):
the line runs around the side of the head and above the fuel lines, will have the copper tube for the mechanical gauge and the factory pressure switch installed, should clean things up a bit.
also took the sandwich plate for the oil cooler out to switch from full flow to thermostatic:
but the o-rings on the fittings for the plate were fucked up, so I have to get new ones before I reinstall- figured I would at least clean up the ends of the lines to get rid of the hoseclamps now that I know how to get the lines all the way together, but that lead to removing the oil cooler entirely and cleaning up all the oil it lost when the line blew off back in like 2004.
now I have to decide if I want to clean up the oil cooler setup, or get new lines and fittings and relocate it... I'm thinking I would have room up front for a shorter oil cooler down low with the 2" vents below the bumper, the intercooler mounted hanging down from the top, and the factory rad with a low profile puller fan on the back.
I'm leaning pretty heavily towards skipping racing at waterfest in favor of finishing the car the right way. I've half-assed this car back together more than a few times to make a deadline, then lost motivation when it came to taking it back apart.
I still have to get that freeze plug out of the oil pan too
stuff I want to do before I put it back on the road:
-finish power steering (need a bunch of fittings and line, cheap, but some research required)
-finish breather system (have all the parts, but spread out all over the place)
-relocate battery to the back with a summit battery box, remove battery tray
-relay headlights (finally)
-clean up remaining vacuum lines and engine compartment wiring
-install hall sender distro and finish wiring spark control
-alignment
paul, should I rewire the fuel injector wiring into two banks?
