January 09, 2009, 07:19:14 PM
On the real though... my pops was in OC tooling around in his Cherokee and he was scared you guys were gonna give him a NOT IMPRESSED. That could ruin a mans own self image!! He told me to go check out all the drunks on the front porch. You guys freakin owned 6th street.- DeezUU on vortex in regards to the H2O house.
77842 Posts in 6039 Topics by 347 Members
Latest Member: Gagabaksiks
| | |-+  Corrados & Sciroccos (Moderator: shislerocco)
| | | |-+  16v serp belt conversion/catch can installation (old news, but my first time)
Pages: 1 2 3 [4] 5 6 ... 9 Print
Author Topic: 16v serp belt conversion/catch can installation (old news, but my first time)  (Read 3743 times)
Re: 16v serp belt conversion/catch can installation (old news, but my first time)
« Reply #45 on: June 02, 2008, 05:37:44 AM »
That flange looks rad. When I did Katie's motor I just used something I had sitting around which means you can get it at Napa.
SpamBot
burkee1483
View Profile WWW Email
« Reply #46 on: June 02, 2008, 06:50:20 AM »
whoooohooo glad i can see this thread finally..
oh..and im part for part...the same build as scott..on the serp/catch can..dealy..
 thumbsup
shislerocco
« Reply #47 on: June 02, 2008, 07:06:29 AM »
you guys are my guinea pigs so i can see what i DONT want to do you're #1!
Then there was the deliverance Hicks being loud in the field. We went and crashed the fuck out of their night. It think it went something like this. Shis = "I have a little Scirroco four banger that will walk all over your shit. Lets race" Next morning shis looked dead in the car.
« Reply #48 on: June 02, 2008, 07:21:11 AM »
I posted a whole thread about that.
SpamBot
burkee1483
« Reply #49 on: June 02, 2008, 07:25:03 AM »
1.9tdi crank pulley 60 bucks brand new from olympic or worldpac...
works just fine with the 16v..its compairable to the abf one..
What had happened?
« Reply #50 on: June 02, 2008, 07:27:55 AM »
lets see some pics of it then.. and your non-ac city golf bracket.
“I’m gonna make you a mix tape. You like Phil Collins?”
 “I have two ears and a heart, don’t I?”
shislerocco
« Reply #51 on: June 02, 2008, 09:23:56 AM »
oh? you still work on that car?  wave
i think i "finished" the engine in that car in less than a year wave
What had happened?
« Reply #52 on: June 02, 2008, 09:36:26 AM »
ooh, sick burn.
 monk
SpamBot
burkee1483
« Reply #53 on: June 02, 2008, 09:43:13 AM »
sounds good ill take some pics of them tonight..
the pulley is sitting at the parts store..but heres a quick refrence
TDI
ABA
« Reply #54 on: June 02, 2008, 10:22:14 AM »
The TDI one looks a lot like the 1.8t one that doesn't work.
SpamBot
burkee1483
« Reply #55 on: June 02, 2008, 10:55:08 AM »
there different only my MM's...
wizardofOD and another guy on vortex sells..theses tdi pulleys to work with the serp setup on 16v's..i figure why pay them 90 bucks when i can get it for 60  thumbsup
1.8t pulley your talking  about
What had happened?
« Reply #56 on: June 02, 2008, 01:14:51 PM »
My brother was nice enough to bring me my stuff from RPW, so I'm headed out the garage after work to get started on some shit.
still need to make a bracket for the catch can out of something, and get the upper rad hose situation sorted out as well.  thumbsup
« Reply #57 on: June 02, 2008, 06:41:40 PM »
Post the alternator bolt ninja shit up so everyone else can do it. It sucks.
What had happened?
« Reply #58 on: June 02, 2008, 09:27:18 PM »
it wasnt as bad as I thought it would be.. your directions were perfect-
from now on, this will be known as the "paul method":
take a 19mm socket, or anything bigger than the lower bushing, a long bolt that is smaller than the shaft of the alternator bolt, a washer or something bigger than the bushing so it presses against it, and a smaller nut that threads onto the small bolt.
hold the end of the bolt and turn the nut in, and it presses that lower bushing back into the mounting ear of the alternator:
one that one was flush with the ear, I ran the top one in slightly to make it easier to line up the alternator on the bracket, then the lower bolt of the alternator snuck right in without hitting the frame rail, making installing the alternator as easy as it could be.. removal is not exactly the reverse of installation, as you'll have to press that bushing back in to get the alternator back out again, so make damn sure you have everything else ready to go before you install it.
alternator installed:
new wiring, since the old exciter wire was an eye terminal instead of a plug (I just took a wire from the old '97 GTI wiring harness and pressed it out of its existing plug, then put it into the lower of the two terminals on the back of the alternator plug, the top remains unused):
hammer tuned frame rail to accommodate serp belt tensioner pulley, probably only necessary on an A1 install:
only hardware other than the stuff already on the 16v is a double sided stud with a 17mm head that goes in the top left mounting position for the water pump, and the crank pulley bolts from an ABA- the water pump pulley is the VR6 one, and when installing it, you have to put it on backwards from the way you think it should be- its pretty obvious that it will only line up one way.
everything installed, now I need to figure out what size belt to get:
remember when I said I wished I'd purchased a 90 degree npt to -10 fitting? now I really wish I had:
rough installed repainted valve cover and new intake to check clearances:
dug this old thing out of storage and cleaned it up, going to try and figure out what I need to do to un-looptune my power steering system... it did still have fluid in it, so that's a good sign... I need a new cap for it.
you'd think with all the fucking fittings I bought that I'd be able to put the new FPR adapter on, the fittings that come with the new one do not work with the original BBM one piece rail. I need to buy more shit to get that to work..
I removed the blue fuel lines, and I did cut the factory double flare end off the fuel line to check the compression fittings paul gave me, and they're going to work just fine. The adapters that summit sent me to convert from 1/4" NPT to -6an are wrong, they're somewhere between -6 and -8. The replacements are apparently in the mail right now.
still on the shopping list:
90 degree -10 fitting for the breather
whatever pipe thread the fuel rail is to -6 o-ring seal fitting
o-ring plug for the passenger side of the rail (the -6 plug I bought is totally the wrong thing)
1.5" or so flat stock to make the bracket for the catch can
oh well, made some progress tonight.. I've been awake about 21 hours now, so I'm going to go die.
anyone have a power steering pressure line for a scirocco, or know if an A2 one will work?
« Reply #59 on: June 03, 2008, 03:51:31 AM »
Looks good, when I did the 'paul method' I used a bolt that threaded into the insert and not one that fit through. Probably works the same.
Glad you're making progress!
