December 04, 2008, 11:49:34 AM
I try to love everybody; the jocks, the nerds, the Brits, people from Kalifornia, MkiV drivers, Democrats, the DCI applebags, and even the Scirocco people.
-Paul@VWvortex
76086 Posts in 5908 Topics by 440 Members
Latest Member: Mnbcfesb
| | | |-+  Need help/ideas, snapped body bolt on A-arm assembly...
Author Topic: Need help/ideas, snapped body bolt on A-arm assembly...  (Read 319 times)
« on: May 07, 2008, 01:19:13 PM »
Wee brother broke this on the Rally car  monk.  Essentially, you have the A-arm, like above, you've got your two bushings...  The rear bushing or one on the right hand side of the above image has a bracket that fits over it and over two studs that emanate from the bottom of the car that you tighten nuts onto.  Well, one of those studs snapped off...  I've never had this happen before.  I had two idea...
1.  Weld on another best as I can.
2.  Grind it off, drill a hole through where it came from, put a bolt/washer in from above floor pan, put a washer below floor pan, place bracket below that washer then bolt.
...ideas?
Krauthammer
Yid Skidder
Re: Need help/ideas, snapped body bolt on A-arm assembly...
« Reply #1 on: May 07, 2008, 01:56:22 PM »
And its not an actual threaded hole with a stud in it, as I recall.
Option 1 seems kinda sketchy, option 2 sounds solid!
Go Blue!
« Reply #2 on: May 08, 2008, 07:35:01 AM »
holy shit.
I am always super careful with putting nuts on those things for fear of crossthreading them.. I have NO IDEA what to do with a snapped off one.
let me know what you end up doing.
did it loosen up? I guess you cant really tell, huh?
« Reply #3 on: May 08, 2008, 07:57:28 AM »
id build a super beffy plae w/ grade 8 bolts that could be welded into palce repalcing the studs on both sides. hell maybe even make it so there are 4 bolts holding that rear mount into place. i was debtiang doing this right off the bat on the rally rabbit iv been working on. but that car is out on the road being beaten silly as i speak!.....
on my caddy, im installing a whole mk2 subframe to get away form the kind of weak/lamo mk1 contorlarms and frame horns.
« Reply #4 on: May 08, 2008, 08:06:00 AM »
what the fuck is a beffy?
« Reply #5 on: May 08, 2008, 08:21:21 AM »
holy shit.
Willdo, no idea if it loosened up, was my brother at the controls while I was at work.  I asked him exactly what happened and he said he thinks he was tightening it when he should have been loosening.  monk - I guess I'm gunna see what type of metal is present, what type of bolstering vw did in that area and I do have a donor car I can cut from, we'll see!
I'll post pix of the carnage.
