Welcome,
. Please
login
or
register
January 09, 2009, 08:46:13 PM
1 Hour
1 Day
1 Week
1 Month
Forever
HOLY SHIT. I think rando just hit you with a tape ball that hit 9 other people at the same time. be careful. DCI throws tape.
Posts in
6039
Topics by
348
Members
Latest Member:
FlewWeewerirgf
Search:
Advanced search
Car & Tech Talk
Performance Parts & Mods
oil cooler setups? 16v
« previous
next »
Pages:
1
2
Author
Topic: oil cooler setups? 16v (Read 731 times)
SpamBot
on:
May 05, 2008, 01:03:52 PM »
its been years since ive owned a 16v..but on my last one was my scirocco i had a sweet mocal setup that i got dirt cheap from this crack head..
i was wondering if anyone on here is running an oil cooler setup and where ya got it from
cause im looking at the ones on eurosport for 150bucks..
http://www.eurosportacc.com/oilcooler.htm
and they look almost like the same ones on the summitracing website for 89bucks
http://store.summitracing.com/partdetail.asp?autofilter=1&part=DER%2D15502&N=700+300459+115&autoview=sku
pschmidt
Re: oil cooler setups? 16v
Reply #1 on:
May 05, 2008, 02:01:26 PM »
Whatever you get, make sure it's thermostatic. A non-thermostatic sandwich adapter will make your oil take forever and a day to come up to temp. Eurosport's description leads me to believe the standard 4 cyl kit doesn't come with the thermostatic adapter.
Poke around racer's part wholesale. You can piece together a kit for right around $250. Don't use rubber line. At the bare minimum run Aeroquip or Russell pushlock. You'll thank yourself later when the contents of your sump aren't all over the road.
Right, kick ass. Well, don't want to sound like a dick or nothin', but, ah... it says on your chart that you're fucked up. Ah, you talk like a fag, and your shit's all retarded. What I'd do, is just like... like... you know, like, you know what I mean, like...Don't worry scrote.
Nuno
Reply #2 on:
May 05, 2008, 02:09:21 PM »
Quote from: pschmidt on May 05, 2008, 02:01:26 PM
Pat speaks the truth.
Reply #3 on:
May 05, 2008, 03:31:03 PM »
Mocal makes nice thermostatic plates for VR, I am sure I saw an option for 1.8's... I got a used volvo oil cooler core that jesse is going to weld -AN fittings on, then I am having the shop down the road make some nice SS braided lines. Ive been told you can get NPT fittings on just once over the brittish standard on the volvo core, If you dont care about disconnecting the lines from the cooler I'd use JBWeld and regular NPT fittings and be cheap and dirty..
I think I remember reading that you can use the oil cooler plate off a volvo on a 1.8 with no problems, do some research and head to a junk yard.. might get lucky and find everything you need for next to nothing.
Nuno
Reply #4 on:
May 05, 2008, 04:17:08 PM »
Quote from: dreadlocks on May 05, 2008, 03:31:03 PM
Reply #5 on:
May 05, 2008, 04:26:46 PM »
I run a Mocal setup on my race car. Thermostatic is the only way to go. it'll heat up to ~85 deg C FAST, then stay there like the gauge is broken. Even after a run at the hillclimb it'll be touching 95 deg. Much better than running 120-140 regularly.
SpamBot
Reply #6 on:
May 05, 2008, 07:36:39 PM »
looks like i ether have to hit the yard and start snaggin...volvo 940T oil coolers with thermo plates..
or start to save some pennys and get a good setup
thanks guys
prizice
Reply #7 on:
May 05, 2008, 10:54:36 PM »
Lets see if I can remember the shopping list
volvo 740T thermo plate + the oil filter stem & corresponding nut (same size, possibly different length, otherwise a nice extra to have laying around)
2x BSP to AN adapters (IIRC volvo plates are British thread, maybe 1/2"?)
2x AN -> Pushlock 90 deg (use whatever angle to route the hose coming off of the plate where you want it to go)
aeroquip push lock hose
2x AN -> Pushlock straight (or whatever angle to mount the cooler)
2x AN to NPT (for summit cooler)
I forget what size cooler I had (see above pic), but the setup cooled very nicely. You could pretty much drain the cooling system and the oil cooler would get you home without overheating. FYI that radiator was the Non AC "Short" radiator.... hence the extra room to mount the cooler on the end.
Last Edit: May 05, 2008, 11:08:21 PM by prizice
prizice
Reply #8 on:
May 05, 2008, 11:03:56 PM »
Don't know the compatibility between 1.8t's and 16v's, but would guess that they could interchange parts since they use the same oil filters and the 1.8t is basically a morphed 16v.
but
it looks like you could fit an s4/v6 oil cooler on a 16v
http://www.modifieda4.com/web/tech/oil-cooler.html
never seen or heard of anyone trying it.... but you could be the 1st.... maybe luck out and find an early v6 audi at the pull 'n part and get it for $5. I'm not sure what came with the bigger cooler though
pschmidt
Reply #9 on:
May 06, 2008, 05:24:24 AM »
Quote from: ApprenticeMike on May 05, 2008, 07:36:39 PM
thanks guys
I have a full volvo setup, minus lines if you want it.
Reply #10 on:
May 06, 2008, 07:55:59 AM »
i run a all OEM volvo set up on my TT, i took the volvo oil cooler and cut off the line fittings for it as ther esoem goofy hard to get type of thread......... and i tig welded on new i think dash-10 AN fittings to it, then for lines i used socetless hose's and fittings. cost me bout 90buks for eveythign!.... works like a champ. and now i can get parts at any race shop in the world if i have probelms down the road. oh and a fram oil filter seal fits teh volvo oil cooers perfact!.... so no need to track down odd seals and shit!
p.s. i got all the volvo parts a a local pull-n-save junk yard for bout 20buks and 3 bloody nuckles.
SpamBot
Reply #11 on:
May 06, 2008, 11:17:39 AM »
pat..whatcha want for it.. i think it will work perfect for what i wanna do
pschmidt
Reply #12 on:
May 07, 2008, 06:57:09 AM »
I paid $50 for it and promptly placed it on the shelf, never to be installed.
I'm not that far from you if you want to grab it.
Reply #13 on:
May 07, 2008, 09:28:42 AM »
"2x BSP to AN adapters" where on earth do u order these? i need 2 right nwo for dradlocks car!..... other wise its tig weld city!
Reply #14 on:
May 07, 2008, 09:33:17 AM »
google found this shit..
http://www.pegasusautoracing.com/productselection.asp?Product=3252
Pages:
1
2
« previous
next »
Please select a destination:
Regional Forums
=> East Coast
=> Pacific Northwest
=> California
=> Colorado
=> NE Eugene (New England)
=> Midwest
=> Southeast
=> Europe
Car & Tech Talk
=> Volkswagens
===> A1 Rabbit/Jetta
===> A2 Golf/Jetta
===> A3 Golf/Jetta
===> A4 Golf/Jetta
===> A5 Rabbit/Jetta/GTI
===> B3-B6 Passats
===> B1\B2\BX Dasher\Quantum\Fox
===> Air-Cooled
===> Corrados & Sciroccos
=> Audis
===> Late Model Audis
===> Early Audis
=> General Auto
=> 2-Wheeled Mayhem
===> Bicycles
===> Motorcycles
=> Performance Parts & Mods
===> Brakes, wheels & tires
===> Forced Induction
===> Electronics & Accessories
===> Fabrication, Bodywork & Tools
===> Carbs, standalone and other N/A goodies
=> Motorsports
===> Rally
===> Drag Racing
===> Road Racing & Autocross
Random Bullshittery
=> youtube
=> Off Topic
===> Music
===> Movies & TV Shows
===> Toys
===> Video Games
===> Politics & News
=> Computers & Electronics
=> Photography & Art
=> Tattoos & other body modifications
=> Health, Fitness & Food
=> Outside Kid Discussion
=> Help & Forum Suggestions
Marketplace
=> Wanted
=> For Sale/Trade
