Welcome,
. Please
login
or
register
January 07, 2009, 11:50:58 PM
1 Hour
1 Day
1 Week
1 Month
Forever
HOLY SHIT. I think rando just hit you with a tape ball that hit 9 other people at the same time. be careful. DCI throws tape.
Posts in
6032
Topics by
335
Members
Latest Member:
CDUnlalloto
Search:
Advanced search
Car & Tech Talk
Volkswagens
Corrados & Sciroccos
(Moderator:
Headlights Relay? WTF is going on here?
« previous
next »
Pages:
1
Author
Topic: Headlights Relay? WTF is going on here? (Read 407 times)
on:
January 07, 2008, 08:24:59 AM »
Went to drive my 85 this morning and the headlights don't work. Tried switching to hi-beam, thinking it might just be a fuse, and I get the transitional 'on for a moment between settings' hi-beam, but they don't work in either position. I assume that since they work between positions on the stalk that it has to be the relay but without a schematic (I'm visiting my GF and don't have my books here) I don't know where to start.
Any suggestions? I have a multimeter and quite a bit of electrical experience, but I usually work with a reference. I also have to have them fixed by tomorrow, as my leave is over on the tenth and I have to make a 300 mile trip across the frozen washington wastelands.
Nuno
Re: Headlights Relay? WTF is going on here?
Reply #1 on:
January 07, 2008, 08:29:20 AM »
Do you have upgraded headlights that require a relay?
Reply #2 on:
January 07, 2008, 08:44:17 AM »
someone should make a FAQ on head light relay set-ups. this comes up a lot. i iknow i could use a refresher!
Nuno
Reply #3 on:
January 07, 2008, 08:47:45 AM »
http://www.vintagewatercooleds.com/tech/Techtips/Timbotechnotes/headlight/Headlight.htm
Reply #4 on:
January 07, 2008, 09:10:44 AM »
It appears to be a factory-stock relay. At least, it's a bosch part on a bracket that's installed right in front of the battery and looks like it belongs there.
It's supposed to isolate the current from the headlights from going through the fuse box, since so many of the fuse boxes before 85 had fried the pins for hi and low beams. Dunno if it works for both hi and low, but the hi-beams most definitely go through there. My suspicion, at this point, is the switch in the dash has gone bad/worked loose.
Nuno
Reply #5 on:
January 07, 2008, 09:55:32 AM »
Thanks for the lesson. But i'm fully aware of what a relay does.
Reason i asked is because you didn't specify if it was OEM lighting or upgraded.
Get yourself a test light in your hand alng with a multimeter and start at the lights and go to towards the switch.
Reply #6 on:
January 07, 2008, 11:40:03 AM »
Quote from: Nuno on January 07, 2008, 09:55:32 AM
Sorry about that. Half of what I write is just to get it straight in my own head. Wasn't trying to be condescending. It's an OEM setup that was introduced in 85, same time they switched to spade fuses.
Went straight for the switch and jumpered it out, lights came on. Took the switch apart and the copper bar, that's supposed to be pushed against the contacts by a spring, wasn't. Freed up the contact and cleaned up the melted plastic and everything works as advertised again.
Nuno
Reply #7 on:
January 07, 2008, 11:53:59 AM »
Reply #8 on:
January 08, 2008, 09:34:59 AM »
Quote from: spite on January 07, 2008, 11:40:03 AM
I would be willing to bet you money that "cleaning up the melted plastic" is a sign of a deeper problem.
my switch in the 87 shorted out in a much different manner and fried several of the wires to the point of having hot insulation dripping on my leg and filling the passenger compartment with smoke.
if you had melted plastic on that plug, it should be replaced, along with any of the connecters that look like they are getting hot.. the last thing you want is wonky resistance behind the dash of a scirocco.
I cant find the pic right now, but I bought the plug and all the terminals to fix it from VW.. granted its a bit easier for me working at a dealer, but its the right way to fix it.. and I wouldnt trust that switch again either.
Reply #9 on:
January 27, 2008, 12:55:07 AM »
Agreed. I think it's because the cheap-ass sylvanias I'm using draw more than the original hellas. It's not the wiring or the connector that's a weak link, but that lame-ass switch. The part that heated up was the copper sliding strip contact inside the headlight switch. Gonna switch the whole thing to relays next weekend and get that current out from under the dash. The wiring that goes to the hi-beam relay is pretty hosed up as well, so I'm going to make a clean sweep of it and run fresh wire for the whole system.
Pages:
1
« previous
next »
Please select a destination:
Regional Forums
=> East Coast
=> Pacific Northwest
=> California
=> Colorado
=> NE Eugene (New England)
=> Midwest
=> Southeast
=> Europe
Car & Tech Talk
=> Volkswagens
===> A1 Rabbit/Jetta
===> A2 Golf/Jetta
===> A3 Golf/Jetta
===> A4 Golf/Jetta
===> A5 Rabbit/Jetta/GTI
===> B3-B6 Passats
===> B1\B2\BX Dasher\Quantum\Fox
===> Air-Cooled
===> Corrados & Sciroccos
=> Audis
===> Late Model Audis
===> Early Audis
=> General Auto
=> 2-Wheeled Mayhem
===> Bicycles
===> Motorcycles
=> Performance Parts & Mods
===> Brakes, wheels & tires
===> Forced Induction
===> Electronics & Accessories
===> Fabrication, Bodywork & Tools
===> Carbs, standalone and other N/A goodies
=> Motorsports
===> Rally
===> Drag Racing
===> Road Racing & Autocross
Random Bullshittery
=> youtube
=> Off Topic
===> Music
===> Movies & TV Shows
===> Toys
===> Video Games
===> Politics & News
=> Computers & Electronics
=> Photography & Art
=> Tattoos & other body modifications
=> Health, Fitness & Food
=> Outside Kid Discussion
=> Help & Forum Suggestions
Marketplace
=> Wanted
=> For Sale/Trade
