January 08, 2009, 12:35:24 AM
The DCI eastside chapter are a gaggle of friggin losers....gang mentality wimps that just want to be included in something. Someone needs the beat the piss out of a few of those f'in applebags just to prove a point that pretending to be a tough guy isn't going to get you far. - some guy with a fake username
77734 Posts in 6032 Topics by 336 Members
Latest Member: LevittraAchatt
| | | |-+  ign. wires getting hot as fuck!!!!!!!!!!!
Author Topic: ign. wires getting hot as fuck!!!!!!!!!!!  (Read 415 times)
jaydub
seigheil1313
« on: December 24, 2007, 02:09:51 PM »
this is like the third time trying to fix it it usually fixes it self but now im gonna tear it down and fix i think its the pig tail on the back of the ign. it seems to be corroded leave your feelings at home!. i followed the wire to the back of the fuse block no problems were found and the wire only gets hot at the back of the ign. leave your feelings at home!,any input would help.the wire is #15 on the back of the ign. switch.
DCI-WEST
brianroyal@msn.com brian_royal
Re: ign. wires getting hot as fuck!!!!!!!!!!!
« Reply #1 on: February 22, 2008, 12:43:48 AM »
I know this is an old post, but try this anyway if you haven't already.
Disconnect both your battery leads and connect a multimeter across the leads to check for resistance. With the key in the off position and the accessory fuse pulled out, you should have a wide open circuit. It should read OL or infinite depending on your meter. If not, there's a short. Check all your switches (turn the interior light switch to the off position) and make sure nothing is on, like maybe your rear window defogger. They shouldn't matter in the off position but if they do, we'll get to that.
If it was wide open, turn the key to the ON position and see what happens to the resistance across the terminals. You should be catching a reading through the ignition switch, a large amount of resistance in the instruments, etc. Should read in the thousands if you have everything shut off. If not...
Start pulling fuses, one by one, and check with each one to see which fuse makes your resistance go back up to where it belongs. Once you find the one that makes a difference, you've found the circuit that has the excessive current draw.
The A1's had almost all the current in the car pass into and out of the passenger compartment. More than that, almost all the power in the car passes through that ignition switch in the early models, so if more than a couple things are drawing a little too much current each, they add up and more current will flow through those wires.
Upgrading your headlights, for example, even to what should be an OEM equivelant, can cause a similar symptom. Course, with that example it would only happen when the headlights are on.
Message me if you're still having problems.
jaydub
seigheil1313
« Reply #2 on: February 22, 2008, 05:09:15 AM »
thanx but i fixed it it was the stock fuel pump relay,my car has a mallory fuelpump and it draw alot of amps the douche who had the car before me wired to the stock relay thumbsup
DCI-WEST
« Reply #3 on: February 22, 2008, 01:25:13 PM »
Right on. Figured it was something that was upgraded.
MotherfuckinEsher
DCI pez dispenser
« Reply #4 on: February 24, 2008, 03:34:40 PM »
Fuck a relay, toggle it throug the rear window defogger. Anti theft anyone thumbsup
I love my iPhone cause I can post shit on this shitshow forum while sitting on the shitter shitting!
« Reply #5 on: March 03, 2008, 02:14:56 AM »
That's fucking brilliant!
