December 03, 2008, 07:12:30 PM
Attn: Everyone. Please give a warm "Dubsquad Welcome" to Euro2.0. He knew a guy that hasn't been a member in almost 10 years. You should all be ashamed of yourselves for not lining up to suck his gigantic cock.
76060 Posts in 5905 Topics by 432 Members
| | |-+  Carbs, standalone and other N/A goodies
| | | |-+  gsxr throtel cable options?
Author Topic: gsxr throtel cable options?  (Read 1119 times)
« on: September 12, 2006, 06:55:39 AM »
so, maybe someone here knows. but.... i am going to stuff gsxr throtel bodies on my aba and wonder what throtel cable i should run?
Duffman
Re: gsxr throtel cable options?
« Reply #1 on: September 20, 2006, 08:32:17 PM »
i'm using a stock scirocco 16v throttle cable, i bent the linkage on the bodies a tad to stuff the cable into it, then trimmed the cable nipple down a tad so as to fit nicely inside the linkage.
« Reply #2 on: September 21, 2006, 09:13:24 AM »
"trimmed.......nipple"......
love
kitchenware
Release the butterflies!
« Reply #3 on: September 21, 2006, 07:12:03 PM »
this is yours isn't it Duff?
Duffman
« Reply #4 on: October 10, 2006, 08:13:45 PM »
yes, that's an early fitment pic for the throttle cable stop...that nipple on the end no longer looks like that and i "manuvered" the linkage on the itb's to cup around the base of that nipple a little better...i have pics on my laptop, which isn't really working right now...but i do have them somewhere.
kitchenware
« Reply #5 on: October 11, 2006, 12:56:06 PM »
neat, post that suckah up.  Another question while I have your attention...  What did you use for couplers?  Size/material?
« Reply #6 on: October 11, 2006, 12:58:48 PM »
yeah post up duff...... i need some motovaton to build my small valve count itb motor!....... hell i need the motor still.... jim can u toss one in yoru pocket and bring it over to my place?.....
i like taco's!..... all kidns butt taclots...... or dirt.... tis all good!
75rusty
Pre-pubescent Applebag
« Reply #7 on: November 02, 2006, 01:51:37 PM »
Im doing the same thing to my '95 gti 2.slow, I got some 1000cc gsxr throttles on ebay.  Just need to get my manifold cut up and some tubes welded on to it...  Then megasquirt it.  Should gain a wopping 6-7 hp.  wow.
Duffman
« Reply #8 on: November 02, 2006, 02:35:46 PM »
wow, forgot about this thread. sorry.
my couplers are silicone couplers that i cut myself from a long tube of it. i got the tube from BBM back when i was working there, they had some leftovers sitting on top of a shelf in the mezzanine...but i found a place locally that carries silicone couplers. i'm pretty sure it's a 1.75 dia 3 ply...i've heard of people going to home depot and using rubber couplers from the plumbing section...would work, but i dont think it would be nearly as resilient, or strong as the silicone.
here's how the cable setup is now...
the fuel rail (standard 16v BBM unit straight off of the shelf)
the brackets for the rail, i'd ideally like something a little sturdier, but the injectors were seated in the injector seats, and i pressed the rail on as far as it would go onto the other end of the injectors, then made the brackets...so it should hold the rail as tight as i had it on there w/o it. i also had to rethread the holes where those bolts go in as they were smaller bolts from the factory...
any other questions? :)
i can get you the part number for my 4 K&N filters, but holy fuck were they expensive...i have more into the 4 filters than i do the rest of the TB setup....$35ea w/ an employee discount!
