December 03, 2008, 07:28:36 PM
I try to love everybody; the jocks, the nerds, the Brits, people from Kalifornia, MkiV drivers, Democrats, the DCI applebags, and even the Scirocco people.
-Paul@VWvortex
76060 Posts in 5905 Topics by 432 Members
| |-+  Audis
| | |-+  Late Model Audis
| | | |-+  s4 seats + boost gauge
Author Topic: s4 seats + boost gauge  (Read 1085 times)
prizice
« on: March 29, 2007, 07:39:21 PM »
I got some upholstery that was similar enough to the A pillars, ripped  the factory stuff off, and glued the new stuff on so I get an exact match from the pod to the pillar.
tear off the old factory fabric
just need to glue on the pod.  The fabric on the pod and pillar are the same, just a difference in lighting.
and access from the back
It's installed in the car, but I need to re-do the pod fabric  since I smudged some glue on the fabric and wrinkled it up a little
I got some s4 seats, but needed to do a little modifying to get a power passenger seat in place of the existing manual.
I got some of these badass nut-rivet thingies to go in the mounting holes where the power seat rails bolt down to
pull some wires and cut off the white manual slider mount that's sticking up out of the carpet
These are the new/old seats...... anyone want a nice set of leather a4 seats?
Seats are installed.... but again, no in car pics
« Last Edit: March 29, 2007, 07:43:16 PM by prizice » Logged
leakypipe
Re: s4 seats + boost gauge
« Reply #1 on: March 30, 2007, 11:16:19 PM »
If they will fit in my mk4, yes.
Staggerlee
« Reply #2 on: April 01, 2007, 08:07:17 PM »
I could maybe use them's.
Staggerlee
« Reply #3 on: April 02, 2007, 02:28:19 PM »
And make sure you get's one of those "anti-buzz" fittings for that gauge, or it's gonna drive you bonkers.
Numbersix
« Reply #4 on: April 09, 2007, 08:11:37 PM »
Hot!
I want to see it with the seats installed. That would have been one of my next mods to that car. The other seats just didn't cut it.
prizice
« Reply #5 on: April 09, 2007, 09:03:40 PM »
Yeah, you haven't seen the beast since I jacked it up to go off-roading
Staggerlee
« Reply #6 on: May 02, 2007, 06:54:06 PM »
Hey Sully-van,
You got a step by step pictorial of how you installed them seats?
I'm gonna have a similar type project on my hands pretty soon:
I guess I won't be needing your old ones after all.
prizice
« Reply #7 on: May 02, 2007, 07:27:34 PM »
Bastid...... I just called you to see if you still wanted them
have fun using the lint eater to pick up all them alcantara fuzz balls
j/k
I was gonna pick me up a complete interior in that scheme, but they got sold before I could pick 'em up
prizice
« Reply #8 on: May 02, 2007, 07:44:37 PM »
oh yeah... and instructions
most everything's there from the factory, you just need to do a little work to complete the install......
For the hardware:
You need to cut the carpet away where the two power seat legs stick out (you can see where to cut in my picture)
A hole is already there where the bolt should thread into, it's just not threaded
Get them there nutserts and stick 'em in the hole.  In retrospect, 1/4" fit the hole perfectly, but I think I would go for the 5/8" size nutsert even though I would have had to drill out a much larger hole.  I can justify the smaller bolt size by looking at the one single peg used in the manual seats, but if I were to do it fresh... bigger is better.  If you want to be really gangster like Joel with the drivers seat install.... he cut the top off, welded a nut or something on underneath, and re-welded the top back on.
cut off the manual seat thingy that sticks up, and make a mental note to get a piece of black plastic that can cover the hole in the carpet (but you never look under your seat, so you'll probably forget to do this)
For electrical:
I had a power drivers seat (that joel installed, not from the factory)..... so all of the factory wiring was on that side.  I made a makeshift wiring harness using bullet and blade connectors to get power over to the passenger side.  Instead of pulling the whole interior apart, I routed the wiring (with the factory wiring harness) under the doorsill area back to under the rear seat, and then back up the other side.
I didn't have factory side airbags..... so I didn't have to deal with hooking the seat airbags up.
if you don't have any power at all going to your old seats.......
heaters...... sorry... I'm guessing a factory harness from the junkyard would be easiest
just for motors.......  take apart the side of the dash to get below the fusebox.... there's a +12v peg there
So seats are up for grab  (brett??  anyone else)
p.s.
anyone know what paint runs for some little pieces of tupperware?
« Last Edit: May 02, 2007, 08:00:37 PM by prizice » Logged
Staggerlee
« Reply #9 on: May 02, 2007, 08:41:04 PM »
Kewl, thanks man!
I hadn't thought about the 'bags.  I wonder what the chances are that the harness are pinned out the same.  Be a bummer to blow the bags outta my brandy new seats the first time I twist the key, no?
You just grind off the center post thing, or get all fancy with a spotweld cutter?
prizice
« Reply #10 on: May 02, 2007, 09:12:48 PM »
I ground the welds off as clean as I could, then pried the whole piece off with a giant ass 4' screwdriver ..... then painted it with black epoxy paint (so it blends in with the carpet until I get a plastic cover, which may be a factory item... maybe?)
your car is newer.... so there's probably a better chance that the wiring connectors are the same for them airbags
