December 03, 2008, 07:21:44 PM
Attn: Everyone. Please give a warm "Dubsquad Welcome" to Euro2.0. He knew a guy that hasn't been a member in almost 10 years. You should all be ashamed of yourselves for not lining up to suck his gigantic cock.
76060 Posts in 5905 Topics by 432 Members
| | |-+  Carbs, standalone and other N/A goodies
| | | |-+  16v on carbs
Author Topic: 16v on carbs  (Read 1283 times)
matty
Pre-pubescent Applebag
16v on carbs
« on: January 02, 2007, 06:43:55 PM »
So nuno and i were talking about carbs, and its seeming more and more what i would like to do. But there are so many things i dont know. I was reading on vortex in the carbs forum, and they said you'd need to run MSD 6A igniton box. How much and where to get? And also where to find carbs, and perhaps a carter pump, since no Fuel Regulator is needed. And is there a special manifold you'd need to fit carbs on a 16v? Im also guessing its not a smart idea to run only horns on the street. Any help is appreciated!  noob!
ronindub
Re: 16v on carbs
« Reply #1 on: January 02, 2007, 07:53:30 PM »
Mike (Red Baron) would have a good amount of info for you on this as he had a carb setup in his rabbit truck.
I purchased most of his stuff with the intent to put it into my Rabbit but I had to sell the Rabbit for school money and who knows when I will find another Rabbit.  Who knows, maybe I should sell it all.
Onto the info you need....
I will post all my links at the end.
Yes you need a special saucy manifold.  Pierce manifolds makes the best one around .  Available here... http://weberpartsdirect.com/  The manifolds are really nice and aren't pieces of shit.
Weber 45s seem to be the best size carbs to rock.  Most guys I have seen run these carbs due to the fact that with proper jetting they can be very well suited to either 1.8 or 2 liter 16vs. Plus they are abundantly available, easy and cheap to repair, and parts are available all over.
The MSD 6A works but the 6AL is the better choice.  I can't rememebr why.  I think it had something to do with the ability of advancing and retarding the ignition timing.  The difference between the 6A and 6AL is only one thing.
Carter 4070 is the way to go.  Just the right amount of fuel.  Summit has them For $70.  http://store.summitracing.com/partdetail.asp?autofilter=1&part=CRT%2DP4070&N=700+4294925239+4294839053+400415+115&autoview=sku
If you are goign to run the webers, you need either an ABF waterneck or a nice machined waterneck from here.... http://www.twminduction.com/Home/sitemap_FR.html.  It's not on their site, but they make it.
Mike ran filters and horns for equal amounts of time on the street.  Neither gave him any problems.  But getting a rock in a horn wouldn't be good.
Here is the setup I have sitting in my garage....
Here are some links that may help you out.
http://www.webercarbsdirect.com/
http://www.racetep.com/webtechpage.html
http://www.carburetion.com/
http://www.redlineweber.com/
http://www.4secondsflat.com/Spark_plug_reading.html
http://rotaryracing.com/ff_watercooled.htm
Hope that helps.
Re: 16v on carbs
« Reply #2 on: January 03, 2007, 07:10:15 AM »
I daily drove horns only on my ITB's for a couple years with no problems, but I wouldn't recommend it.  I think I was lucky.  For pumps CB performance has a good inline pump, I believe by Carter for about $45.  I'd also recommend Webers just for parts availability.  I'm running Dellorto's, and they work great but a couple parts I need are NLA anywhere.
Re: 16v on carbs
« Reply #3 on: January 03, 2007, 11:57:00 AM »
You can run a bone stock ignition section from a CIS or CIS-e car if you want. All you'll need is a decent vac signal off the carbs.
matty
Re: 16v on carbs
« Reply #4 on: January 03, 2007, 12:28:47 PM »
thanks alot for all the great info and links
jaydub
seigheil1313
Re: 16v on carbs
« Reply #5 on: January 03, 2007, 12:44:26 PM »
im currently running dual 45's on 16v 1.8 stroker dont use anything but a holley pump!!ive tried um all.as far as ign. i use a electromotive but u can use a msd.my manifold is custom bilt by my buddy. i use 180 air correctors,f-2 emultion tubes,145 main jets(165's work best but only get's around 8 m.p.g.)but that is here in cali. if u need any more info hit me up here is my set up
DCI-WEST
Re: 16v on carbs
« Reply #6 on: January 03, 2007, 02:21:14 PM »
8 mpg wow........ that has to be fun..... makes my truck seem like a good daily driver ahah...... how much HP u making?
jaydub
seigheil1313
Re: 16v on carbs
« Reply #7 on: January 03, 2007, 04:52:45 PM »
i hav'nt dynoed it yet but im gonna make a stab and say 160-175 mark.
DCI-WEST
Re: 16v on carbs
« Reply #8 on: January 03, 2007, 07:33:54 PM »
Mike speaks....thought he was a mute.
Glad you could help out matty
matty
Re: 16v on carbs
« Reply #9 on: January 04, 2007, 07:32:13 AM »
yes, thanks alot. The only problem is getting $800 for just the carbs. But as nuno told me, you gotta pay to play.
Re: 16v on carbs
« Reply #10 on: January 08, 2007, 06:38:46 AM »
For $800 if you're crafty and can read you can set up DIY ITB's and Megasquirt. Not as cool as carbs, and not as cool as 8mpg, but neat otherwise.
Re: 16v on carbs
« Reply #11 on: January 08, 2007, 09:49:39 AM »
itb's not as cool as carbs........... i dont know bout that..... having to sit on the side of the road and synk your cabrs cant be much fun when your in a hurry some where and everythin go;s to hell for no reason..........  there is a dci member local to me w/ a set of itb's and the correct spacer for them to fit a 16v vw!.......
Re: 16v on carbs
« Reply #12 on: January 08, 2007, 01:02:44 PM »
Don't steal from Duff, it's mean. Well, unless he really deserves it.
Re: 16v on carbs
« Reply #13 on: January 08, 2007, 01:21:47 PM »
nop\e...... a CO dci member!...... and it snot me!
Oldskool84
Re: 16v on carbs
« Reply #14 on: January 21, 2007, 04:38:01 PM »
I really liked Holley pumps.  I ran one along with the Holley regulator on my Beetle with dual 44's for a while, no problems.
There's a dude on Vortex getting 171 WHP on a 9A block with Webers and 276 cams.
"Just add more timing, you'll be fine."------ VR6 Paul
'96 GTI VR6 ...  24.00 @ 2500
                       (quarts @ miles)
