November 23, 2008, 03:55:35 AM
Attn: Everyone. Please give a warm "Dubsquad Welcome" to Euro2.0. He knew a guy that hasn't been a member in almost 10 years. You should all be ashamed of yourselves for not lining up to suck his gigantic cock.
75684 Posts in 5875 Topics by 256 Members
Latest Member: DFscalseclink
| | | |-+  Converting from FI to Carb?
Author Topic: Converting from FI to Carb?  (Read 385 times)
« on: October 01, 2008, 11:00:01 AM »
car: 1.6L FI 78' Rabbit
I recently procured a 2L ABA bottom/JH top motor for very cheap which is currently setup with the passenger side pointing intake and FI.
I have a single draft carb (Holley 5200) jetted for a 2L on an 8v intake.  I think it'd be more fun to have the carb on then run FI and would love to run a clean engine bay.
Anything I should know about this swap?  The linkage I'm not worried about, I can do that jazz.  I think I'd need a different gas tank/fuel pump.  Ideas?
Re: Converting from FI to Carb?
« Reply #1 on: October 01, 2008, 11:35:57 AM »
u can keep the same fuel pump if u put on a super good FPR or so im told. and i belive u can use the stock ignition system all on its own w/ a carb......  should be a super kake swap, are u worried about going back to OEM EFI? if not ....... u can clean up a shit ton of stuff super easy.........
« Reply #2 on: October 01, 2008, 01:28:54 PM »
Just swap a regular rabbit intake manifold onto it and everything else will plug in.
« Reply #3 on: October 01, 2008, 02:53:40 PM »
To keep the FI?  I wanted to run this swank carb I have/had on the rally car...
rabbit jake
« Reply #4 on: October 01, 2008, 06:14:56 PM »
the carter fuel pump is only like 75 bucks.  On Rando's, we installed that pump, and capped off the return line.  Ignition is stock CIS coil, distributor, and ICM.  Super easy conversion.
« Reply #5 on: October 01, 2008, 07:06:36 PM »
Sweet, that sounds like exactly what I'm ginna do.  Where did you pick up the pump?
« Reply #6 on: October 02, 2008, 07:00:57 AM »
Nevermind, I found an electric bosch fuel pump that I bought originally for my RoadRunner that I never used except for siphoning gas ;)
« Reply #7 on: October 02, 2008, 08:23:31 AM »
Check it's pressure rating and if needs a reg.  Here's what I run/ran, will run again, on the Race car.
http://www.cbperformance.com/catalog.asp?ProductID=577
Seriously, sounds like more work to do the swap if you're wanting a cheap driver.  But it's your car :)  Once you figure out CIS I love it's simplicity.
Randy 2 socks
evrytmeIdie
« Reply #8 on: October 02, 2008, 08:10:07 PM »
carbs don't like high psi pumps and stock cis pumps put out like 95psi or something crazy like that.  I would suggest getting a really good fpr or splurging the $70 for the carter fuel pump.  i believe its the 4070.
http://www.jegs.com/i/Carter/180/P4070/10002/-1
theres a place to get them cheaper but its only like $8 cheaper.  worth it if you don't want to destroy your o rings in that carb.
resident gargoyle
MotherfuckinEsher
DCI pez dispenser
« Reply #9 on: October 08, 2008, 11:51:22 PM »
You're supposed to be able to run the Carter pump minus a FPR but I'm running one. 3psi
I love my iPhone cause I can post shit on this shitshow forum while sitting on the shitter shitting!
« Reply #10 on: October 09, 2008, 06:10:30 AM »
Esh, which FPR are you running?  I've seen a couple Holley FPRs that adjust down that far, thanx for posting what psi you were runnin.  3psi seems like a good spot for carbs.
« Last Edit: October 09, 2008, 06:15:08 AM by attackrabbit » Logged
MotherfuckinEsher
DCI pez dispenser
« Reply #11 on: October 15, 2008, 07:27:11 AM »
I believe mine is a holly.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HLY-12-804&N=700+4294925239+4294839053+4294880914+115&autoview=sku
« Reply #12 on: October 15, 2008, 07:31:02 AM »
Awesome, thanx man.  The more info the better, due to traveling for work I probably won't get this done till I get back from all my traveling for work (mid-November).
