December 03, 2008, 03:28:29 PM
i know a few guys from DCI your lucky im nice or id be on the phone with a few of them right now - MyVWsPhatter
76042 Posts in 5905 Topics by 430 Members
Latest Member: Bentenzycle
|-+  Random Bullshittery
| |-+  Computers & Electronics
| | |-+  anyone want to fix my laptop hard drive?
Author Topic: anyone want to fix my laptop hard drive?  (Read 225 times)
marylandNick
a1vwrabbit
« on: September 05, 2008, 02:45:05 PM »
its a mechanical failure in the hard drive... every now and again it will come up but usually just black screen and does nothing. i know you can take desktop hard drives apart and usually repair them, but is it possible with an old IBM think pad drive?
i've got two think pads now with this same problem. brain damage!
I'm making sexy fat....
unsuitable for work
World revolves around me, dont ya know? Fuck sake!
Re: anyone want to fix my laptop hard drive?
« Reply #1 on: September 05, 2008, 03:15:29 PM »
As I tried to tell you before your friend took your computer.... there are programs designed to pull the information off the hard drive, in order to save the information.  Don't quote me but I think you can also have the hard drive replaced.  It costs money though.
Life is pain, but you just have to scrape the joy out of it.
marylandNick
a1vwrabbit
« Reply #2 on: September 05, 2008, 03:18:51 PM »
im pretty sure the harddrive has to be able to start up in order to use those. i'm more worried about keeping the programs on it rather than the files.... i know it's something dumb.
« Reply #3 on: September 05, 2008, 03:28:24 PM »
It does have to run to pull anything off of it.  Your programs are files - one thing you might try and do is the whole hard drive in the freezer trick.  Put the drive in a ziplock back and toss it in the freezer, let it sit overnight, pull it back out, hook it up and copy your shit off to a spare drive.
You can get mobile hds for not terribly expensive through an incredible universe, frys, newegg I believe that should work fine.  If you can't get anything off of it you can send it in to have the data retrieved off the raw platters but it's expensive.
Not sure who told you that you can take desktop hard drives apart and usually repair them, that is extremely difficult.  That is not trivial in the slightest and usually not worth the trouble.
MrJoshua
Limey Squad
mrjoshua@hotmail.co.uk
« Reply #4 on: September 05, 2008, 10:03:42 PM »
The only time I've ever taken a drive apart to make it work was about 14 years ago when I first started in IT.
The drive just needed a little "push" to get the platters spinning.  Once they broke inertia they'd spin fine.
I second the freezer trick in this instance Nick.
Cheers
Josh
Putting the I into DCI
egecko
55572362 egecko@hotmail.com egeck0 egecko
« Reply #5 on: September 07, 2008, 03:02:54 AM »
make sure you have it connected as a secondary and then copy whatever you can to the larger primary so you don't have to worry about it taking time to boot up/warm up.   or  if you have an imaging program that will make an image of the drive, so you can place that on your new 2.5" hdd. I used to use PowerQuest Drive Image, V2i Protector (PowerQuest was acqiured by Symantec in 2003) all the time at the last comapny I worked for and I still have all of that software I used. I was the one that they would let play with newer versions of different software before it was deployed to the field service techs. The drive doesn't have to be a primary to make an image. You can create the image (.pqi) on either a hdd or discs. Image can also be deployed over newtwork remotely. I'll see if I can find it and send it your way and hopefully it will help. I also had all kinds of data recovery software and there was a time when an engineer deleted all of his data...... and I recovered it for him.
if you're interested, here's a review of V2i Protector.
« Last Edit: September 07, 2008, 03:17:46 AM by egecko » Logged
marylandNick
a1vwrabbit
« Reply #6 on: September 07, 2008, 09:52:50 AM »
i'll give the freezer trick a go... i have a 320 gig external drive, should i just put like windows or something on that? will the laptop strart up using the external drive as it's main memory source? im about computer retarded, so if these questions seem dumb i appologize.
my friend works with computers all the time and said he's done it to desktop drives when he absolutly had to get shit off of them... said he's done it on a few, i may use him as a last resort  both are fucked up.
thanks for the info guys seriously. thumbsup
