my engine specs....1915cc
machined block- bored for 94mm pistons, tapped for full flow.
demello machine shop 69mm counter weighted crank <- these guys are funny as shit to talk to you on the phone
balanced rods...also by dms
engle fk87 cam, straight cut cam gears, 30mm lifters 1.4:1 rockers
heads: 3 angle valve job, last cooling fin cut off to bump compression, cork gaskets
full flow pump, spring loaded push rod tubes
carbs: dual dell 40's....they do the job for now.
thats what i can remember off the top of my head. going N/A for this year....motor for next year is going to require me to put a cage in my car. i should have a built trans by early summer. i won to get atleast 1 picture of me lifting the front wheels off the ground.
so if anyone comes across a set of dell 45's.....let me know. haha.
