November 21, 2008, 08:50:05 AM
Although reports are intermittent, and written in the prose of a poorly educated 6th grader, it seems that the Southeast is still Shambles Central.
75629 Posts in 5871 Topics by 253 Members
Latest Member: ToillPaibplaupe
| | |-+  Air-Cooled (Moderator: Nuno)
| | | |-+  wiring thoughts
Author Topic: wiring thoughts  (Read 372 times)
Train Wreck
loudwagen
wiring thoughts
« on: February 27, 2008, 09:04:42 PM »
im looking to buy a harness to rewire the 57 and make it fully 12v and i have some thoughts/questions...
 if i were to buy a main harness for a 74 (motor to fuse box) and buy a complete harness for a 57, would i run into alot of problems with putting the two together? or should i just get a complete harness for a 74?
info, tips or anything you all could tell me would be great
Re: wiring thoughts
« Reply #1 on: February 28, 2008, 05:34:45 AM »
It all depends on what you want out of your conversion.
But you don't need to replace your harness.
-the 6-volt harness is of a heavier gauge than the 12 volt.
If your 6v starter and flywheel haven't been replaced you don't need to either.   I had a 6v starter on my 12v system and it worked great.
What you need to complete your 12v conversion for your car to operate correctly is...
12 v Generator/alternator, coil, and carb (with choke).
As for accessories you can put resistors on all the 6v bits or change the bulbs to 12v.
You will need a 12v wiper motor or you can use a 67 wiper motor and switch.
If you "must" re-wire your 58...look up Wiring Works Kit.
If i were you i would work with the wires you have now.  If they are beyond repair or just need a new harness you can get a 74 harness.
For wiring the Alternator with your old harness look here:
http://www.nls.net/mp/volks/schem/gen_alt.gif
Train Wreck
loudwagen
Re: wiring thoughts
« Reply #2 on: February 28, 2008, 01:14:24 PM »
thanks nuno, im thinking that a new harness for a 74 will need to be ordered very shortly. the one i have now is in a box and is all cut up and covered in red paint, and to me its not worth using. i do have all the parts to make it the car operate correctly minus the wiper switch and ill pick one of those up when i make an order for the harness.
Re: wiring thoughts
« Reply #3 on: February 28, 2008, 01:17:53 PM »
Yeah if going new.
I would go with a 74 harness.
Although a 58 would be almost the same.
Many different ways to do the conversion.
burnt63
Who shot me?
Re: wiring thoughts
« Reply #4 on: February 28, 2008, 01:22:35 PM »
i glad i'm not the only one full of useless, but useful to others, information on aircooled beetles.  thumbsup
'63 bug "burnt63"......'67 bug "project smurf"...... '98 gti "bracketracingdaillydriver"
Re: wiring thoughts
« Reply #5 on: February 28, 2008, 01:26:41 PM »
burnt63
Who shot me?
Re: wiring thoughts
« Reply #6 on: February 28, 2008, 01:51:59 PM »
marylandNick
a1vwrabbit
Re: wiring thoughts
« Reply #7 on: February 28, 2008, 03:37:39 PM »
we need to make it look something like this...
I'm making sexy fat....
MotherfuckinEsher
DCI pez dispenser
Re: wiring thoughts
« Reply #8 on: February 28, 2008, 04:40:30 PM »
Some how I don't see that happening. you're #1!
I love my iPhone cause I can post shit on this shitshow forum while sitting on the shitter shitting!
pschmidt
nihilist7777
Re: wiring thoughts
« Reply #9 on: February 28, 2008, 04:49:37 PM »
I can snag a bunch of weather pack connectors if you guys want to get all fancy like.
I consider myself to be having a 'good luck day' when only 1 horrible thing happens.
marylandNick
a1vwrabbit
Re: wiring thoughts
« Reply #10 on: February 29, 2008, 04:57:42 PM »
i like the way you think thumbsup
