November 21, 2008, 09:05:26 AM
Breaking News: East Coast has suffered dramatic and sudden changes in membership, as a salt cloud covers the North West over a controversy in San Diego? Details at 11.
75629 Posts in 5871 Topics by 253 Members
Latest Member: ToillPaibplaupe
| | |-+  A3 Golf/Jetta
| | | |-+  crackpipe questions....
Pages: [1] 2 Print
Author Topic: crackpipe questions....  (Read 913 times)
marylandNick
a1vwrabbit
« on: September 06, 2007, 01:57:43 PM »
is there a trick that i dont know of to getting the pipe back into the water pump? i tried for a good twenty minutes and i cant get it in at all.... duff, paul, scuba?
« Last Edit: September 06, 2007, 04:32:20 PM by marylandNick » Logged
I'm making sexy fat....
Re: crackpipe questions....
« Reply #1 on: September 06, 2007, 04:03:41 PM »
i use a quick spritz of lube works fine......... do u have  a stianless one or a plastic? iv heard the stianless one's sometimes fit realy tight on that end.
marylandNick
a1vwrabbit
« Reply #2 on: September 06, 2007, 04:32:03 PM »
its just the oem plastic one... i tried putting a little oil on it and it still wouldnt go.  maybe i need to sand down the water pump to clean some of the shit out of it... i'll try a little more lube tomorrow, maybe i just wasnt liberal enough.
« Reply #3 on: September 06, 2007, 04:41:34 PM »
i push and spin when i install them and it seems to just pop in like when uv got on a comdom w/ out enough lube!.....
marylandNick
a1vwrabbit
« Reply #4 on: September 06, 2007, 04:58:44 PM »
cool i'll give that a go. thanks jess.
Balloon Knot Goggles
KABLAZZIE
bmxdubdub bmx_v_dubdub
« Reply #5 on: September 06, 2007, 05:54:32 PM »
I had trouble until I cleaned out the corrosion around the pump bore.
I fucking hate crack pipes.
Who's got a fucking coat hanger?
dci shambles
marylandNick
a1vwrabbit
« Reply #6 on: September 06, 2007, 06:04:03 PM »
i hate mk3's.  you shouldnt have to pull the entire motor apart to fix a fucking coolant leak
KABLAZZIE
« Reply #7 on: September 06, 2007, 06:08:59 PM »
 :pissedblu2:
dci shambles
marylandNick
a1vwrabbit
« Reply #8 on: September 06, 2007, 06:18:26 PM »
yeah, her crack pipe didnt even break. it was the hose going from the oil cooler to the block.  but i replace both those hoses and the pipe. i already told her i'm not doing that again.
KABLAZZIE
« Reply #9 on: September 06, 2007, 07:14:57 PM »
Even if you tried to replace just the small hose I can guarantee that nipple would've broke.  Mine broke just from being a weak pussy piece of shit.
dci shambles
Duffman
« Reply #10 on: September 06, 2007, 08:03:02 PM »
those 2 hoses make the samco kit worth while in my mind...but only if you plan on keeping the car a long while.
its a shame you cant buy just those 2 hoses from samco, easily.
i take it a little sand paper/emry cloth and more lube worked out?
Scuba
scubavr6
« Reply #11 on: September 06, 2007, 10:19:08 PM »
white lithium paste, turn and push
MrJoshua
Limey Squad
mrjoshua@hotmail.co.uk
« Reply #12 on: September 06, 2007, 11:09:10 PM »
Can you not approach SiliconHoses.com to see whether they'd do them?
Cheers
Josh
Putting the I into DCI
« Reply #13 on: September 07, 2007, 08:12:11 AM »
hay nick, how about a d42d or what ever yoru work is called develops the new crackless pipe, iv been thnking about this.
alunanum fitting for the water pump area and one at the distro block, then straight cylicone in the center. done,  and easy to make custom fittings to go mid stream in the scylicone for what ever others may need?....
marylandNick
a1vwrabbit
« Reply #14 on: September 07, 2007, 02:16:47 PM »
thats a good idea, but how would you hold it in the waterpump... seems to me its just held in there 1 by rust build up and by the fact that the other end cant go anywhere once bolted in.  and i dont work there anymore so... i have no say in what is made.
duff, i havent tried today... its about 98 with 100% humidity and the mosquitos around here eat people alive... and i'm out of off. i think if i sand down that build up a bit and lube it more liberally it will go in.
thanks everyone for the help.  well, and early thanks anyway.
Pages: [1] 2 Print
