December 04, 2008, 09:08:38 PM
On the real though... my pops was in OC tooling around in his Cherokee and he was scared you guys were gonna give him a NOT IMPRESSED. That could ruin a mans own self image!! He told me to go check out all the drunks on the front porch. You guys freakin owned 6th street.- DeezUU on vortex in regards to the H2O house.
76113 Posts in 5912 Topics by 444 Members
Latest Member: beisseMut
| | |-+  A3 Golf/Jetta
| | | |-+  dyno'd again today...
Pages: 1 [2] Print
Author Topic: dyno'd again today...  (Read 1922 times)
marylandNick
a1vwrabbit
Re: dyno'd again today...
« Reply #15 on: June 27, 2007, 06:51:47 PM »
his car still has full leather interior... he's not so into having a gutted car. he likes em nice.
I'm making sexy fat....
jiveturky
jiveturky3
« Reply #16 on: August 12, 2007, 09:51:20 PM »
what the fuck is an open element intake temp sensor?
No sked jus fire!
« Reply #17 on: August 13, 2007, 05:17:19 AM »
See how there are little holes? They're so it responds faster, the VW 1.8T one is similar but even more open. I can make 'open' ones out of the stock ones now, also.
yuk
Excited!
yukismobile
« Reply #18 on: August 13, 2007, 06:00:28 AM »
i like this thread... too bad my vr is stupid slow with stock cams  :pissedblu2:
Smile.
« Reply #19 on: August 13, 2007, 11:36:26 AM »
I bet you $6.79 that I can run 13.5 or quicker with stock cams.
Duffman
« Reply #20 on: August 13, 2007, 12:12:10 PM »
you dont happen to know the thread pitch on those GM sensors do ya? i can't find that info anywhere and i've asked machinists/fab guys at work and they can't figure it out either...i'm sure it's something simple, but most of those guys are used to standard NF/NC threads and NPT threads...with the occasional port thread...but it doesn't seem to be any of those.
yuk
Excited!
yukismobile
« Reply #21 on: August 14, 2007, 07:56:58 AM »
Are you running Aftermarket motor mounts? Any advice on the BFI stuff? Thinking about getting the .5, unless youe stage 1's are really not too bad...
Smile.
« Reply #22 on: August 14, 2007, 07:49:04 PM »
Just from the pic it looks like a straight thread, could be 1/2-20, it looks like it.
Yes old ass Turn2 ones going to convert to delrin for the rear two and solid front. I don't buy BFI as they're complete rips of the old T2 stuff but don't work as well. They're VERY soft IMHO.
yuk
Excited!
yukismobile
« Reply #23 on: August 15, 2007, 04:53:08 AM »
i have a turn 2 front one, but the motor is moving alot, i can feel it.... any suggestions paul or will you have anything i can grab from ya?
Smile.
« Reply #24 on: August 15, 2007, 07:27:34 AM »
The VF mounts are nice but $$$$. Joe and I have something in the works but nothing commercial yet.
Duffman
« Reply #25 on: August 16, 2007, 12:27:08 AM »
i'll vouch for the vf's, i have all 3 in my car. the only person that thinks the vibration is bad is lil chris, but hes used to those pillows that came as factory mounts in his car...
the tranny mount, however, is flawed. if you arent carefull, the "nut" that goes through the middle of the poly can slip through and fall into the cup. on top of that, there isnt really anything preventing the "nut" from spinning endlessly when trying to tighten the bolt through the trans bracket. anddont get me started on their stupid washer....
the hyperformace/hpa mount though, top notch. its everyhing the vf trans mount is, with the flaws fixed. the "nut" has a flared shape to it with the poly molded around it, preventing it from slipping through the poly into the cup. in addition to that, the top of the "nut" is similar to that of the factory mount with the two tabs that actually lock onto the transbracket, preventing it from spinning endlessly. and to top it of, they dont have the stupid washer the vf does that almost always falls off when trying to get everything back together.
their motor mounts, being incredibly similar to turn2 and bfi, are improved upon too. apparently its a dual compound poly. slightly softer for the idle vibrations, yet still MUCH stiffer than factory. and there was something to do with them when temps get cold, as soon as energy is put to them (read: engine starting) they go from being harder than the norm to exactly the same compound hardness as any other time of year, unlike most other poly mounts. or something along those lines.
Pages: 1 [2] Print
